can to ethernet gateway
Posted: Tue 16. Jun 2026, 12:05
by robotguy1
Hello, does the driver handle the can to ethernet gateway the same way as the can to usb adapter? Meaning that I can directly interface with my can devices trough can0, can1 etc..? (As with the usb adapter). Or do I have to use a protocol to translate my can-messages before i send them downstream to my can devices?
Re: can to ethernet gateway
Posted: Wed 17. Jun 2026, 08:33
under Windows we offer the Virtual PCAN-Gateway software tool, which will handle the PCAN-Ethernet interfaces similar as a direct connected PCAN-PC-interface. Unfortunately this option is not available under Linux. Here you have to write an own application using the Ethernet protocol definitions:
https://www.peak-system.com/produktcd/P ... on_eng.pdf
Posted: Wed 17. Jun 2026, 09:30
by robotguy1
Thank you! Would it work to have a gateway at each end of the ethernet cable, and then just treat it as regular canbus from both side, and let the gateways to the protocol conversion?
Posted: Wed 17. Jun 2026, 09:54
Yes, this is possible. Please see quick start guide page 8 for more details:
https://www.peak-system.com/produktcd/P ... rt_eng.pdf
