Send a request to the ECU with a serial terminal
ArakelTheDragon
Post by ArakelTheDragon » Tue 15. Oct 2019, 09:25
Hi guys,
I have made my own serial terminal which can send data over the "USB" in "char" or "hex" format. I want to use it to send a message to the "ECU" and receive a response. When I send "0x22 0x40 0x09" I receive random numbers as the response "0x30 0x35....." with size about 250 bytes. Is it not a simple system, "USB -> USB to RS232 converter -> RS232 to CAN converter -> ECU" ?
I believe the "frame format" is not correct, can someone tell me the whole "frame format" that I have to send over the "USB"?
Re: Send a request to the ECU with a serial terminal
Post by M.Maidhof » Tue 15. Oct 2019, 10:15
which PCAN hardware do you use?
Post by M.Maidhof » Tue 15. Oct 2019, 12:31
to use our PCAN-USB under Windows please have a look on the PCANBasic API, which you can download from our support website. If you use Linux, you can use the SocketCAN driver of the kernel, or use the peak-linux-8.x chardev driver. But both systems don't use any serial commands. The PCAN-USB is not a COM interface.
ArakelTheDragon
Post by ArakelTheDragon » Tue 15. Oct 2019, 15:14
How come they don't take serial commands? Its a company device, I am just using it. My serial terminal manages to connect sucessfully.
Post by M.Maidhof » Tue 15. Oct 2019, 15:35
OK fine, when it is working even with serial commands.
ArakelTheDragon
Post by ArakelTheDragon » Wed 16. Oct 2019, 23:54
Doesn't really answers my question? What is the whole frame format and size?
Post by M.Maidhof » Thu 17. Oct 2019, 09:29
yes, but who should answer that question? There are millions of "ECUs" on the marked, so how should anybody know which version you are using.
ArakelTheDragon
Post by ArakelTheDragon » Thu 17. Oct 2019, 21:57
Can you please give me standard RobertBosch BMW ECU frame or similar?
Post by M.Maidhof » Fri 18. Oct 2019, 09:28
well, this is a PEAK System Forum, which will take care about issues with PEAK System CAN and LIN products. In your case, it will be better to ask your question in a BMW or Bosch ECU forum. We don't know such ECUs, and can't tell you anything about it.
