PCAN-LIN CT: bug on double clic in Default Data Frame conff
R1MARC
Post by R1MARC » Wed 28. Nov 2018, 14:09
if you double click in "Default Data" area of "Frame Configuration" on LIN bus, the application freezes: solution is to kill it...
Re: PCAN-LIN CT: bug on double clic in Default Data Frame co
Post by M.Maidhof » Wed 28. Nov 2018, 14:26
just tested, but working as aspected. No freeze.
More details about used OS, software version, PCAn-LIN configuration file and RS232 traffic will be helpful to find the cause of that problem.
R1MARC
Post by R1MARC » Wed 28. Nov 2018, 14:57
Windows7
2 PCANLIN-CT in same time, each one has its own USB/RS232 port and its gateway
V3.0.8.141
Gateway CAN to LIN configuration with copy of all frames to RS232.
Low bus load as there are 2 frames each 250ms.
It looks like a lock due to "RS232" traffic.
I'll have to restart the machine and may retry with only 1 application started.
U.Wilhelm
Post by U.Wilhelm » Thu 29. Nov 2018, 22:17
Topic Closed - no PEAK-System problem
