Cannot connect to PCAN-LIN
jeff_lynn
Post by jeff_lynn » Thu 25. Jun 2020, 17:07
I have a PCAN-LIN device, and as the title says, I cannot connect to it using the PCAN-LIN CT software. The device itself is working, and I have been able to connect to it and send commands using a terminal emulator, but doesn't work with its configurator software. I use windows 10 64 bit, and as my pc lacks serial ports, an usb to serial converter. What can be the problem?
Re: Cannot connect to PCAN-LIN
Post by M.Heidemann » Fri 26. Jun 2020, 08:34
Thank you for your request!
Can you please check the following?
Open up Device-Manager and check your device (Should be listed under COM) properties, which manufacturer is listed there?:
Please report back to me with your findings.
jeff_lynn
Post by jeff_lynn » Fri 26. Jun 2020, 09:04
Hi Marvin,
It is Prolific. Yesterday we tried using an another one that was a different brand but I cannot remember what is was, but it didn't work either.
Gyula
Post by M.Heidemann » Fri 26. Jun 2020, 09:30
Hello Gyula,
We know of issues with adaptors using Prolific chips.
Adaptors using FTDI chips will work with the PCAN-LIN.
