Heavy time latency in Python script
giles
Post by giles » Tue 22. Dec 2020, 14:02
I try to read CAN msgs and then transmit the processed CAN msgs via PEAK CAN-USB in Python (with the Py) environment, while I found there is a heavy latency communication between PCAN-View and Python environment as shown in below pictures.
I simulate the signals from WIN10 PCAN-View and you can see the count number in ubuntu is less than the number in WIN10 PCAN-View
and the same situation we can found the Data is also different at the same time
I also tried in ubuntu PCAN-View transmit to ubuntu Python, also occurred the above situation.
Hardware: PCAN-USB Pro FD
And below is the Python code contents:
from PCANBasic import *
import time
channel = PCAN_USBBUS1
baud = PCAN_BAUD_500K
## The Plug & Play Channel (PCAN-USB) is initialized
# objPCAN =# The Plug & Play Channel (PCAN-USB) is initialized
objPCAN = PCANBasic()
result = objPCAN.Initialize(channel, baud)
if result != PCAN_ERROR_OK:
    # An error occured, get a text describing the error and show it
    print(result[1])
    channel = PCAN_USBBUS2
        print(result[1])
    else:
        print("PCAN-USBx was initialized")
else:
    # Check the status of the USB Channel
    result = objPCAN.GetStatus(channel)
if result == PCAN_ERROR_BUSLIGHT:
    print("PCAN-USB (Ch-x): Handling a BUS-LIGHT status...")
elif result == PCAN_ERROR_BUSHEAVY:
    print("PCAN-USB (Ch-x): Handling a BUS-HEAVY status...")
elif result == PCAN_ERROR_BUSOFF:
    print("PCAN-USB (Ch-x): Handling a BUS-OFF status...")
elif result == PCAN_ERROR_OK:
    print("PCAN_USB (Ch-x): Status is OK")
else:
    print(*result[1])
while (True):
    start = time.perf_counter()
    objPCAN.FilterMessages(channel, 119, 119, PCAN_MESSAGE_STANDARD)
    RecMegs = objPCAN.Read(channel)[1]
    print(RecMegs.ID)
    print(list(RecMegs.DATA))   # extract the data from CAN Read call back module
    # Send the data to CAN bus
    msg = TPCANMsg()
    msg.ID = 0x56
    msg.MSGTYPE = PCAN_MESSAGE_STANDARD
    msg.LEN = 8
    msg.DATA[0] = 0x08
    msg.DATA[1] = 0x00
    msg.DATA[2] = 0x00
    msg.DATA[3] = 0x80
    msg.DATA[4] = 0x00
    msg.DATA[5] = 0x00
    msg.DATA[6] = 0x00
    msg.DATA[7] = 0x00
    time.sleep(0.01)
    result = objPCAN.Write(channel, msg)
        print(result)
    else:
        print("Message sent successfully")
    end = time.perf_counter()
    duration = end - start
    print(duration)
    print(' ')
# All initialized channgels are released
result = objPCAN.Uninitialize(PCAN_NONEBUS)
    print(result)
else:
    print("PCAN-USBx was UN-initialized")
Re: Heavy time latency in Python script
Post by M.Heidemann » Tue 22. Dec 2020, 14:47
You do not seem to read until the ReceiveBuffer is empty,
which could be the cause for this.
Please make sure that you read messages in a loop based on the condition that the message-queue is not empty (Using return value TPCANStatus.PCAN_ERROR_QRCVEMPTY).
Otherwise you will only read the next message in the buffer, which might is older.
This is also described in the PCANBasic API documentation:
Furthermore you can take a look at the PCANBasic example for Python included in the PCANBasic package,
the same mechanism is used there:
https://www.peak-system.com/fileadmin/m ... -basic.zip
 def ReadMessages(self):
        stsResult = PCAN_ERROR_OK
        # We read at least one time the queue looking for messages.
        # If a message is found, we look again trying to find more.
        # If the queue is empty or an error occurr, we get out from
        # the dowhile statement.
        while (self.m_CanRead and not (stsResult & PCAN_ERROR_QRCVEMPTY)):
            stsResult = self.ReadMessageFD() if self.m_IsFD else self.ReadMessage()
            if stsResult == PCAN_ERROR_ILLOPERATION:
                break
Please report back to us if this has solved your issue.
giles
Post by giles » Wed 23. Dec 2020, 17:36
Thanks very much for your guidance sir, and it indeed help me to have a progress in real-time message receiving and transmitting.
But now some message is lost which I simulated the increasing message with step of 1, marked with red rectangle box.
Screenshot from 2020-12-24 00-25-19.png (47.31 KiB) Viewed 9239 times
And below is the code content:
import time
    print(result[1])
        print(result[1])
    else:
else:
else:
    print(*result[1])
i = 0
while (True):
# Message data receiving module, and as the buffer will store the received data from CAN BUS
# So below 2 steps need to follow:
# Step 1:
#   Check the data in Buffer, if have data, continue to check buffer status
# Step 2:
#   If current buffer is empty, break the while loop and print the last Msgs Data
    while (objPCAN.Read(channel)[0] & PCAN_ERROR_OK) == PCAN_ERROR_OK:
        stsSystem = objPCAN.Read(channel)[0]
        RecMsg = objPCAN.Read(channel)[1]
#        if stsSystem == 0:
#            print('Status of system is:', stsSystem)
        if (objPCAN.Read(channel)[0] & PCAN_ERROR_QRCVEMPTY) == PCAN_ERROR_QRCVEMPTY:
            break
    if RecMsg.ID != 0:
        print('CAN BUS Data is: ', list(RecMsg.DATA)[0])
    msg = TPCANMsg()
    msg.ID = 0x56
    msg.LEN = 8
    msg.DATA[0] = 0x08
    msg.DATA[1] = 0x00
    msg.DATA[2] = 0x00
    msg.DATA[3] = 0x80
    msg.DATA[4] = 0x00
    msg.DATA[5] = 0x00
    msg.DATA[6] = 0x00
    msg.DATA[7] = 0x00
    time.sleep(0.05)
        #print(result)
    else:
        i = 2
        #print("Message sent successfully")
    #print(duration)
    #print(' ')
    print(result)
else:
giles
Post by giles » Fri 25. Dec 2020, 01:55
And below is the relevant code about the message status checking:
            break
    if RecMsg.ID != 0:
but as I descript in above last replay, some messages are lost when Python script receiving. Could you please help to check it what's happened ?
                break
giles
Post by giles » Fri 25. Dec 2020, 11:05
Dear Sir,
I found the CAN bus empty status checking code may be the root cause for the messages lost
Is this sentence need more time to process in your basic software?
and now I will filter the messages ID which I want in main loop while out of the while loop.
to check if the code receive the messages via if the ID of message is 0.
with above process, code now can work normally and messages also can be received completely.
But no CAN status check information now in code, so if you have a better solution with CAN status judgement, could you please inform me and thanks very much for your great support.
   while (True):
#        stsSystem = objPCAN.Read(channel)[0]
        if RecMsg.ID != 0:
            print(list(RecMsg.DATA))
            break
Post by M.Heidemann » Fri 25. Dec 2020, 19:20
i noticed you use the return of "PCAN_ERROR_OK" as your condition for the read loop, which might leads to
the behaviour you have seen, as you will break the condition as soon as something else is returned, wether or not the queue
is actually empty at this point.
The ideal implementation is shown in the PCANBasic Python example,
which is exactly the reverse order:
The function read messages will either call "ReadMessageFD" or "ReadMessage" (Depending on the messagetype) as
long as "PCAN_ERROR_QRCVEMPTY" is not returned.
Look for the function "ReadMessages" in the Python example of the PCANBasic Package:
                break
The called functions will check for "PCAN_ERROR_OK" and will only
process the message if it is returned (Processing could be printing the message, for example):
def ReadMessage(self):
        # We execute the "Read" function of the PCANBasic
        result = self.m_objPCANBasic.Read(self.m_PcanHandle)
        if result[0] == PCAN_ERROR_OK:
            # We show the received message
            self.ProcessMessage(result[1:])
        return result[0]
The "ReadMessages"-function itself is called by either on timer-tick,with a receive event or manually on call.
In your case you might want to implement a timer based version of the read,
please see the provided example for Python in the PCANBasic-Package to see how this can be implemented.
Please let us know, if this was helpful to you.
giles
Post by giles » Mon 4. Jan 2021, 12:19
Dear Sir,
Thanks very much for your swift response, and the main reason maybe out of I invoke the Read function twice, so lead the data update in buffer, now I update the code as below, all issues are killed now.
Besides, do we have the .dbc file decode file example for python or cpp which can realize the data decoding in real-time from CAN bus with the .dbc file application?
Thanks very much and have a nice day and happy new year.
    while (True):
        sysStatus = RecMsg[0]
        RecData = RecMsg[1]
        #if RecMsg.ID != 0:
        if sysStatus != PCAN_ERROR_QRCVEMPTY:
            print(list(RecData.DATA))
            i = i + 1
            print(i)
            break
Post by M.Heidemann » Mon 4. Jan 2021, 12:25
We are glad that you were able to resolve your issue.
We do not offer examples to implement a DBC-file parser, you'll need to implement
this yourself.
giles
Post by giles » Wed 6. Jan 2021, 15:31
Thanks very much for your great support!
