PCAN-View TRC file time offset seems to be off
jdlogicman
Post by jdlogicman » Wed 24. Mar 2021, 22:24
As you can see, the time offset is definitely not milliseconds since the start:
;$FILEVERSION=2.0
;$STARTTIME=44278.7302169329
;$COLUMNS=N,O,T,I,d,l,D
;   Start time: 3/23/2021 17:31:30.743.0
;   Generated by PCAN-View v4.3.3.610
;   Connection                 Bit rate
;   PCANLight_USB_16@pcan_usb  Nominal 1 MBit/s, Data 8 MBit/s
;   Message   Time    Type ID     Rx/Tx
;   Number    Offset  |    [hex]  |  Data Length
;   |         [ms]    |    |      |  |  Data [hex] ...
      1 4294967295.796 FD 1F203ECC Rx 64 CB 48 00 00 44 00 99 A2 E7 05 00 91 0B 00 00 05 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 20 10 E0 00 A5 5E 00 00 1F 00 00 00 2C 01 05 00 D8 21 01 00 01 00 19 00 19 00 00 00 00 00 00 00 00
Reason: Inserted [code] tag for improved readability
Re: PCAN-View TRC file time offset seems to be off
Post by M.Maidhof » Thu 25. Mar 2021, 07:42
please provide some more details:
- which PCAN-USB Version (serial number) is in use?
- which firmware version?
- which driver version?
- please disconnect the PCAN-USB device, restart Windows, and connect it again.
jdlogicman
Post by jdlogicman » Thu 25. Mar 2021, 18:34
It's a PCAN-USB Pro FD
SN: IPEH-004061 13480
Driver: PCAN_USB 4.2.2.16474
Firmware: 3.2.0
It shows the bad timestamps in the Trace tab.
I was able to reproduce it until I restarted the computer. Restarting the computer seems to have resolved the issue.
Is this a known issue? I need to hand of a set of work instructions to our technicians, and if restarting the PC after installing the driver will make it reliable, I'll do that.
Thanks!
Post by M.Maidhof » Fri 26. Mar 2021, 09:03
all used files are ok. The timestamps in our drivers are based on the PerformanceCounter of Windows. So if this internal Windows timer will provide such a strange timestamp value, it will also be available in our driver. We have seen this only a few times before, but we are not sure how this happens. This could be an issue based on Windows updates where a necessary reboot was not performed. If this will happen again, please contact us again by email through our support email address to check your system and to find out what causes the problem.
