If I do this:
TPCANStatus stsResult = CAN_InitializeFD(Channel, BitrateFD);
free(BitrateFD);
When I toss away a pointer, it could cause leak. Who releases the string passed and when it is safe to release it?
/// <summary>
/// Initializes a FD capable PCAN Channel
/// </summary>
/// <param name="Channel">"The handle of a FD capable PCAN Channel"</param>
/// <param name="BitrateFD">"The speed for the communication (FD bit rate string)"</param>
/// <remarks>See PCAN_BR_* values
/// * Parameter and values must be separated by '='
/// * Couples of Parameter/value must be separated by ','
/// * Following Parameter must be filled out: f_clock, data_brp, data_sjw, data_tseg1, data_tseg2,
/// nom_brp, nom_sjw, nom_tseg1, nom_tseg2.
/// * Following Parameters are optional (not used yet): data_ssp_offset, nom_sam
///</remarks>
/// <example>f_clock=80000000,nom_brp=10,nom_tseg1=5,nom_tseg2=2,nom_sjw=1,data_brp=4,data_tseg1=7,data_tseg2=2,data_sjw=1</example>
/// <returns>"A TPCANStatus error code"</returns>
