Execute macro when received some data
se_akr
Post by se_akr » Mon 11. Jul 2022, 14:16
Hello everyone,
I'd like to change the color of a led in my panel related to the data received from CAN.
More exactly, I will receive some data from CAN and the color of the led will be green is value is inside the interval otherwise the led will be red. I know it is not possible to do this directly from Instruments Panel that's why I'd like to do it with a macro.
Is it possible to execute a specific VBS macro only when data from a specific CAN ID is received ? If yes, how ?
That would be wonderful, because in this case I could easily control the data's value.
Thanks in advance for your time.
Best regards.
Re: Execute macro when received some data
Post by PEAK-Support » Mon 11. Jul 2022, 14:30
If you use the LED you could define a color on value and a color off value. If you need more as 2 values to set a color of a LED, you also could use the Bitmaplist.
The Bitmaplist could handle n-simple pictures (for example use a circle for a LED).
The Bitmaplist have a Property called Value
Sets the threshold value for the currently selected bitmap. If the value of the Signal that was linked to the Bitmap List reaches this threshold value, then the selected bitmap is displayed in the Bitmap List.
So it is easy to create your own LED with changing colours depending on the Signal Value without use a VBS Macro.
No - this is not possible with the VBS or Std-Macros. You could use the PE6 CallBack Interface DLL Option to create such a function by your own, but the workload is much higher as use the Bitmap List.
If you need more information, you also could contact us per E_mail --> suport[at]peak-system.com
se_akr
Post by se_akr » Mon 11. Jul 2022, 15:01
Thanks for you fast reply,
Bitmap List seems to be interesting, but there is something I don't understand. When I am editing the Bitmap Item, it is "Signal Value" and not "Signal Threshold". Even though it is named "Signal Value", is it really talking about a threshold ?
Post by PEAK-Support » Mon 11. Jul 2022, 15:14
The value is used to "switch" from Bitmap x to Bitmap y. there is no hysteresse included.It is the limit that the value must reach, to change the bitmap.
Value ----> Bitmap
up to 14 --> LED_Off
From 15 to 24 --> LED_A
From 25 to 44 --> LED_B
From 45 to 64 --> LED_C
From 65 to 69 --> LED_D
From 70 to 89 --> LED_C
From 90 to 99 --> LED_B
Higher 100 --> LED_A
se_akr
Post by se_akr » Mon 11. Jul 2022, 15:21
Ok I see. Finally, it is possible to "simulate" an hysteresis:
Value ---> Bitmap
This is just an example, but led will be green between 85 and 169
Thank you so much for your help
Best regards
