Hello, I am working on a CY8KIT-059 CAN Protocol. I have bought a PCAN-USB.
I have the Rx and Tx pins from the board being attached to the CAN Low, and CAN High pins using jumper cables. Proper termination with 120ohm resistor is being used via a connection through a breadboard (I understand this rig is a bit wacky).
My code is set up to transmit incrementing values, however, when I go on PCAN-View Trace option, only one thing is being displayed Rx, Type: Status, Length:4, Data: BUSHEAVY, I have attached a picture. Any ideas on what could be wrong?
Feel free to ask more questions/request pictures, as I would really like this to work.
Forgive me for being new to this all, as I am sure there are better questions being asked.
New to CAN
New to CAN
- help.PNG (4.92 KiB) Viewed 6288 times
- PEAK-Supporter
Re: New to CAN
As no one knows what exact you do, it is hard to answer .....
As you get a physical Error (BUSHEAVY - to many erro frames - counter reach the Top Level) check the CAN Basic
Also spend some tie in reading the CAN Layer 2 specification.
- exact timing
- good cables
- correct termination (2 x 120 Ohm resistors on each end of the CAN-H / CAN-L lines )
Re: New to CAN
Thank you for your reply! I think something I first want to check is the timing. My board runs at 24MHz, while the PCAN-View (CANSJA1000) works at 8MHz. Below is the timing I have picked for both, and I am wondering if they are valid configurations. I have used the Peak Bit Rate calculator tool to do this-- however, I am no professional and would like a second pair of eyes.
- Board Timing Configuration
- board timing.PNG (318.38 KiB) Viewed 6259 times
- PCAN-View Timing Configuration
- PCAN View.PNG (4.76 KiB) Viewed 6259 times
- PEAK-Supporter
Re: New to CAN
The frequency is not the problem. You could use a pre-scaler. But search for a pair of timing parameter that fit. The most important value is the Sample point (try values between 75-85%)
