Guidance to verify a defective CAN-Transceiver
Post by G.Lang » Fri 3. Dec 2010, 13:10
Below a short guidance to verify a defective CAN-highspeed transceiver (for example NXP82C251 or MAX3057ASA)
1. Start the computer and take care that the CAN-hardware is built-in or plugged in
2. Please take care that no CAN-application is running or using the PCAN-hardware (for example: the LED from the PCAN-USB adaptor must be ON and not flashing), otherwise please close the application
3. Disconnect the CAN-connector or CAN-cable physically from the module
4. Please measure with a multimeter (DC measurement area) the voltage the between pin 2 (CAN-L) and pin 3 (GND) from the 9 pole D-SUB. You should measure 2.5V +/- 0.2V :D
5. Now measure the voltage between pin 7 (CAN-H) and pin 3 (GND) from the 9 pole D-SUB, you should also measure 2.5V +/- 0.2V :D
6. If you measure other voltages :shock: then it looks that the CAN-transceiver is defective :cry: (through overvoltage or static electricity charge)
Note: This is only a quick check
