I would like to know if the PCAN-USB pro has a terminal resistor 120 ohms already incorporated.
Terminal resistor PCAN-USB Pro
Re: Terminal resistor PCAN-USB Pro
The PCAN-USB Pro does not have an internal termination.
You could use our PCAN-Term termination adaptor to terminate your CAN bus:
https://www.peak-system.com/PCAN-Term.270.0.html?&L=1
We would always recommend to use termination adaptors due to the fact, that is it alot more flexible of a solution and prevents issues later on, such as overtermination.
