PCAN-Router Pro FD Power Cable / Connector
maneeshsin01
Post by maneeshsin01 » Mon 23. Aug 2021, 12:32
I just got the device PCAN-Router Pro FD.
How could I power on the device.
I checked the documentation shows mating connector.
Where can I buy the female mating adaptor, so that I could power on the device.
Also, for Adaptor for 6 pin i/o.
Appreciate your response and any help.
Thanks, :D
Maneesh
Re: PCAN-Router Pro FD Power Cable / Connector
Post by M.Heidemann » Mon 23. Aug 2021, 12:36
Hello Maneesh,
Thank you for your request.
Where are you located?
Post by M.Heidemann » Mon 23. Aug 2021, 12:38
Also,
check the packaging of the PCAN-Router Pro FD again, both the connectors (Phoenix Contact MC1,5/6-STF-3,81 - 1827745 /Phoenix Contact MC1,5/3-STF-3,81 - 1827716) should be included
with your PCAN-Router Pro FD.
maneeshsin01
Post by maneeshsin01 » Mon 23. Aug 2021, 12:45
Thanks marvin.
I am located at Ingolstadt.
I have two connector but how to use them?
I really dont have any idea .
Post by M.Heidemann » Mon 23. Aug 2021, 12:56
Dear Maneesh,
as for acquring additional connectors:
A quick search on the web will show vendors offering these connectors:
  • Phoenix Contact MC1,5/6-STF-3,81 - 1827745
  • Phoenix Contact MC1,5/3-STF-3,81 - 1827716
As for the usage of the connectors, please see the manual on page 10/11:
For examples of the usage of I/O in firmware, see example "08_HW_IO" in Hardware\PCAN-Router_Pro_FD of the PEAK Developer Package:
https://www.peak-system.com/quick/DLP-DevPack
maneeshsin01
Post by maneeshsin01 » Mon 23. Aug 2021, 13:12
Thank you.
Where can I get/buy ready to use power connector/adaptor to power on the device?
Maneesh
Post by M.Heidemann » Mon 23. Aug 2021, 13:47
Any power supply within the specs (8 -30 V) of the PCAN-Router PRO FD can be used, please see the manual on page 10/11 as mentioned earlier:
maneeshsin01
Post by maneeshsin01 » Mon 23. Aug 2021, 14:00
Thank You.
I have alredy read this documentation.
Do you have any videos/documents ,in general how to use these mating connector.
How can i attach the wire ?
What kind of wire i need ?
What are tools used to wire up these connector?
Post by M.Heidemann » Mon 23. Aug 2021, 14:14
Please see the corresponding specifications of the connectors for more information.
