PCAN MIO Characteristic Curve
Techteam
Post by Techteam » Fri 7. Oct 2022, 09:32
I would like some clarification about characteristic curves with PCAN MIO. The tutorial covers applying a characteristic curve to a received message. I want to apply a characteristic curve to an analogue input and then transmit the corrected value. As the measured value is transmitted and not received will it still apply the curve if I follow the tutorial and create a second message.
Re: PCAN MIO Characteristic Curve
Post by G.Lang » Fri 7. Oct 2022, 13:25
yes, that´s also possible. Below an example with doubles the analog input to the output
Configuration:
analog_in-with_curve.ppproj
(14.32 KiB) Downloaded 16 times
For more infos please take a look into the PCAN-MIO tutorials.
Techteam
Post by Techteam » Mon 10. Oct 2022, 08:41
Thanks. Excellent reply.
Kind Regards
U.Wilhelm
Post by U.Wilhelm » Thu 13. Oct 2022, 16:44
Topic closed
