This is a forum dedicated to discuss suggestions about the functionality of any software product as well as the study of new interesting ideas to develop
U.Wilhelm
Post
by U.Wilhelm » Fri 30. Sep 2016, 12:04
If you have many Trace files (for exapmple btr or trc files from our Hard & Software Tools) and need to convert them with our PEAK Converter, you could use a simple batch file to save work.
Simply run the command line option to convert more than one file in a batch.
Here a sample how to convert all Sessions of *.btr files in the current directory to the PCAN Trace Format 2.0 format. Target is a user definded directory:
@echo on
For %%i In ("*.btr") do PEAK-Converter.exe %%i /TF:PCAN /TC:1.3 /TD="C:\Users\Admin\Desktop\TEST Converter"
More Info could be found in the Help File of the converter.
snieves77
Post
by snieves77 » Thu 14. Sep 2017, 00:08
The help files that get downloaded with the converter are blank. I'm trying to batch convert files but I want it to maintain the filename. Can you point me in the right direction?
Thanks!
- Blank help file
- Peak Help.PNG (11.4 KiB) Viewed 3432 times
- Software Development
Post
by K.Wagner » Thu 14. Sep 2017, 08:45
Dear,
your file seems to be blocked by Windows Security. This is normal when downloading *.CHM files from the internet. Just open the properties of the help file "PEAK-Converter_en-US.chm" (e.g. by right clicking on the file, and selecting "Properties"), and
unlock the file. According to your Windows version, you will see
an "Unlock button",
- Unlock using a button
- Button.png (11.31 KiB) Viewed 3430 times
or an "Unlock check box"
- Unlock using a checkbox
- CheckBox.png (8.86 KiB) Viewed 3430 times
