DBC for IPE-00211002021
Programmable Sensor Module with CAN Connection
Rajeevnaik9590
Post by Rajeevnaik9590 » Mon 25. Nov 2019, 09:49
Hello team,
We are having peak-can gps,(IPEH-00211002021) we need to change the bardrate from 500 kbd to 1mbd.
please support us how to proceed.
B/R
Rajeev naik
Re: DBC for IPE-00211002021
Post by M.Heidemann » Mon 25. Nov 2019, 10:37
Hello Rajeev,
You can use another Peak-device (For example a PCAN-USB) to flash the firmware of your PCAN-GPS.
You will need the PCAN-GPS-Package, you can download it here:
http://www.peak-system.com/fileadmin/me ... cangps.zip
For further information on how to use the software included, refer to the documentation for PCAN-GPS , starting from chapter 6.1.
Included in your download is a folder called "Examples".
In there you will find examples for different uses but also the DeliveryFirmware, you could copy this folder and modify it to your liking.
If all you need is to change the baudrate of the delivery-firmware, you can change the baudrate within /src/can_user.c to one of the baudrates already defined in /inc/can_user.h.
Look for the line:
CAN_InitChannel(CAN_HW_BUS2, CAN_BAUD_500K);
change it to:
CAN_InitChannel(CAN_HW_BUS2, CAN_BAUD_1M);
Compile it using the Yagarto Toolchain (Like explained in chapter 6.3 of the documentation) and flash it
to your PCAN-GPS (Like explained in chapter 6.4 in the documentation).
