C# PCAN-Ethernet Gateway DR Library
CAN to LAN gateway in DIN rail plastic casing
mmagnuson
Post by mmagnuson » Fri 10. Jul 2020, 21:59
I have created a simple C# library that allows for easy communication with a PCAN-Ethernet Gateway DR over IP networks that other developers might find useful. The library enables bi-directional communications to a PCAN-Ethernet Gateway DR hardware (See: https://www.peak-system.com/PCAN-Ethern ... .html?&L=1)
Please note; I have not implemented the PCAN-Gateway Handshake, and I only support UDP communications at this point. Licensing is under Apache License 2.0.
https://github.com/Mmagnuson/CAN_Ethernet_Gateway
Re: C# PCAN-Ethernet Gateway DR Library
Post by PEAK-Support » Sat 11. Jul 2020, 16:36
Thank you ! We will also try it and if you like we could extend it to support also the new CAN FD Ethernet Gateway which will be available soon.
