RP1210 specify adapter
So when connecting using the rp1210 driver it seems like it just grabs whatever interface that happens to have an rp1210 net set to channel 0 but what if you want to use a different adapter? When I scan for devices using the rp1210 driver it only ever seems to return a single channel as available.
Re: RP1210 specify adapter
Please see the RP1210.pdf that comes with the product. There you find the Info how to setup RP1210A and RP1210C Devices.
