PEAK Hardware support Sauer Danfoss Tool PLUS+1™ GUIDE
The PLUS+1™ GUIDE Software from Sauer Danfoss could also be used with any PEAK-CAN PC Interface via the RP12010 Interface DLL.
Re: PEAK Hardware support Sauer Danfoss Tool PLUS+1™ GUIDE
How do I get that dll?
RP1210 development package?
or can I get it somewhere for free?
Thanks in advance!!
Thanks in advance!!
you need to buy a license in order to use the PCAN-RP1210 API. Please take a look at the product page PCAN-RP1210 (A/C)
I have bought the USB-CAN interface and the RP1210 API and installed it.
Unfortunate I am not able to go online:
I can select the PCAN-USB
It seems it parsed well (for RP1210A) ... any suggestions ??
From the Danfoss RP1210 log:
Parse results for: C:\Windows\RP121032.INI:
--PCANRP32
Parsing: PCANRP32
Parse results for: C:\Windows\PCANRP32.ini:
Name: PEAK-System Technik GmbH
Address1: Otto-Roehm str. 69
Address2: (Not specified)
City: Darmstadt
Country: Germany
State: Hessen
Postal: 64293
Telephone: 0049-6151-817320
Fax: 0049-6151-817329
VendorURL: (Not specified)
Version: (Not specified)
RP1210 Version: A
*** WARNING *** [C:\Windows\PCANRP32.ini] Gateway uses RP1210A. See the user manual for information on RP1210A requirements.
CANFormatsSupported:
RP1210A only support 250k, so set: CANFormatsSupported = 4
Protocols: 10,20
Devices: 1,2,3,4,5,6,8,
C:\Windows\system32\PCANRP32.dll exported functions:
GetLicenseInfo
GetLicenseStatus
RP1210_ClientConnect
RP1210_ClientDisconnect
RP1210_GetErrorMsg
RP1210_GetHardwareStatus
RP1210_ReadMessage
RP1210_ReadVersion
RP1210_SendCommand
RP1210_SendMessage
RegisterPCANRP32
RegisterPCANRPChannel
UnregisterPCANRP32
UnregisterPCANRPChannel
Attempting to add protocol: 10
Protocol: 10
ProtocolDescription: Generic CAN Protocol
ProtocolString: CAN
ProtocolSpeed:
RP1210A only supports 250k, so set: ProtocolSpeed = 250
ProtocolParams:
Device: 1
DeviceId: 1
DeviceDescription: PEAK PCAN-not Plug and Play
DeviceName: peakcan
DeviceParams: PCANRPNET
Device: 2
DeviceId: 2
DeviceDescription: PEAK PCAN-ISA card
DeviceName: pcan_isa
DeviceParams:
Device: 3
DeviceId: 3
DeviceDescription: PEAK PCAN-Dongle
DeviceName: pcan_dng
DeviceParams:
Device: 4
DeviceId: 4
DeviceDescription: PEAK PCAN-PCI card
DeviceName: pcan_pci
DeviceParams:
Device: 5
DeviceId: 5
DeviceDescription: PEAK PCAN-USB
DeviceName: pcan_usb
DeviceParams:
Device: 6
DeviceId: 6
DeviceDescription: PEAK PCAN-PCCARD
DeviceName: pcan_pccard
DeviceParams:
Device: 8
DeviceId: 8
DeviceDescription: PEAK PCAN-LAN
DeviceName: pcan_lan
DeviceParams:
Successfully added protocol: 10
Attempting to add protocol: 20
Protocol: 20
ProtocolDescription: J1939 Link Layer Protocol
ProtocolString: J1939
*** SKIPPED *** "ProtocolString" must be CAN
Failed to add protocol: 20
C:\Windows\PCANRP32.ini parsed successfully
1 RP1210 vendor files parsed successfully
Reason: Inserted code tag for improved readability
yes, it seems as it was parsed well. Please take into account, that you need to set a PEAK-Net to be "RP1210", otherwise your device will not able to connect. Check the documentation for PCAN-RP1210 A (PDF: chapter 2.3, PCAN-RP1210A Configuration - CHM: Introduction/PCAN-RP1210A Configuration).
I have set the Net Configuration.
Still no change (have changed in Danfoss Gateway to new channel) and is the message "no valid RP120 license found" of any importance ?
During install of the API 1210 I did not have to enter the serial no. that was with the CD.
the problem is the license. The application cannot find a valid license. You must have received a license file together with the RP1210 setup file. The RP1210 setup takes the needed information from that file at installation time. The file is called PCANRP1210.lic.
I have the file on the CD ... but how to insert it or where to copy it to ?
If you received a CD then you have also the license in there. You have to call the setup directly, so that it can find the license file (copy both files to the desktop or other folder in your PC). So, remove the PCAN-RP1210 and install it again. If you still has problem with this, then contact us per mail, support[at]peak-system.com, and we will give you a tool for system checking.
