PEAK Hardware support Sauer Danfoss Tool PLUS+1™ GUIDE
RP1210 Development Package and RP1210 Connectivity to PEAK CAN Interfaces
Post by PEAK-Support » Tue 12. Feb 2013, 15:12
The PLUS+1™ GUIDE Software from Sauer Danfoss could also be used with any PEAK-CAN PC Interface via the RP12010 Interface DLL.
Daniel Hirsch
Re: PEAK Hardware support Sauer Danfoss Tool PLUS+1™ GUIDE
Post by Daniel Hirsch » Thu 6. Apr 2017, 14:40
How do I get that dll?
RP1210 development package?
or can I get it somewhere for free?
Thanks in advance!!
Post by K.Wagner » Thu 6. Apr 2017, 14:55
you need to buy a license in order to use the PCAN-RP1210 API. Please take a look at the product page PCAN-RP1210 (A/C)
Oystein
Post by Oystein » Fri 28. Dec 2018, 16:03
I have bought the USB-CAN interface and the RP1210 API and installed it.
Unfortunate I am not able to go online:
I can select the PCAN-USB Image
It seems it parsed well (for RP1210A) ... any suggestions ??
From the Danfoss RP1210 log:
Parse results for: C:\Windows\RP121032.INI:
--PCANRP32
	Parsing: PCANRP32
	Parse results for: C:\Windows\PCANRP32.ini:
		Name:        PEAK-System Technik GmbH
		Address1:    Otto-Roehm str. 69
		Address2:    (Not specified)
		City:        Darmstadt
		Country:     Germany
		State:       Hessen
		Postal:      64293
		Telephone:   0049-6151-817320
		Fax:         0049-6151-817329
		VendorURL:   (Not specified)
		Version:     (Not specified)
		RP1210 Version: 	A
		*** WARNING *** [C:\Windows\PCANRP32.ini]	Gateway uses RP1210A. See the user manual for information on RP1210A requirements.
		CANFormatsSupported:
		RP1210A only support 250k, so set: CANFormatsSupported = 4
		Protocols: 		10,20
		Devices: 		1,2,3,4,5,6,8,
		C:\Windows\system32\PCANRP32.dll exported functions:
			GetLicenseInfo
			GetLicenseStatus
			RP1210_ClientConnect
			RP1210_ClientDisconnect
			RP1210_GetErrorMsg
			RP1210_GetHardwareStatus
			RP1210_ReadMessage
			RP1210_ReadVersion
			RP1210_SendCommand
			RP1210_SendMessage
			RegisterPCANRP32
			RegisterPCANRPChannel
			UnregisterPCANRP32
			UnregisterPCANRPChannel
		Attempting to add protocol: 10
		Protocol: 10
			ProtocolDescription: 	Generic CAN Protocol
			ProtocolString: 	CAN
			ProtocolSpeed:
			RP1210A only supports 250k, so set: ProtocolSpeed = 250
			ProtocolParams:
			Device: 1
				DeviceId: 		1
				DeviceDescription: 	PEAK PCAN-not Plug and Play
				DeviceName: 		peakcan
				DeviceParams: 		PCANRPNET
			Device: 2
				DeviceId: 		2
				DeviceDescription: 	PEAK PCAN-ISA card
				DeviceName: 		pcan_isa
				DeviceParams:
			Device: 3
				DeviceId: 		3
				DeviceDescription: 	PEAK PCAN-Dongle
				DeviceName: 		pcan_dng
				DeviceParams:
			Device: 4
				DeviceId: 		4
				DeviceDescription: 	PEAK PCAN-PCI card
				DeviceName: 		pcan_pci
				DeviceParams:
			Device: 5
				DeviceId: 		5
				DeviceDescription: 	PEAK PCAN-USB
				DeviceName: 		pcan_usb
				DeviceParams:
			Device: 6
				DeviceId: 		6
				DeviceDescription: 	PEAK PCAN-PCCARD
				DeviceName: 		pcan_pccard
				DeviceParams:
			Device: 8
				DeviceId: 		8
				DeviceDescription: 	PEAK PCAN-LAN
				DeviceName: 		pcan_lan
				DeviceParams:
		Successfully added protocol: 10
		Attempting to add protocol: 20
		Protocol: 20
			ProtocolDescription: 	J1939 Link Layer Protocol
			ProtocolString: 	J1939
			*** SKIPPED *** "ProtocolString" must be CAN
		Failed to add protocol: 20
	C:\Windows\PCANRP32.ini parsed successfully
1 RP1210 vendor files parsed successfully
Reason: Inserted code tag for improved readability
Post by K.Wagner » Wed 2. Jan 2019, 08:11
yes, it seems as it was parsed well. Please take into account, that you need to set a PEAK-Net to be "RP1210", otherwise your device will not able to connect. Check the documentation for PCAN-RP1210 A (PDF: chapter 2.3, PCAN-RP1210A Configuration - CHM: Introduction/PCAN-RP1210A Configuration).
Oystein
Post by Oystein » Wed 2. Jan 2019, 15:03
I have set the Net Configuration.
Still no change (have changed in Danfoss Gateway to new channel) and is the message "no valid RP120 license found" of any importance ?
During install of the API 1210 I did not have to enter the serial no. that was with the CD.
Post by K.Wagner » Wed 2. Jan 2019, 15:14
the problem is the license. The application cannot find a valid license. You must have received a license file together with the RP1210 setup file. The RP1210 setup takes the needed information from that file at installation time. The file is called PCANRP1210.lic.
Oystein
Post by Oystein » Wed 2. Jan 2019, 15:21
I have the file on the CD ... but how to insert it or where to copy it to ?
Post by K.Wagner » Wed 2. Jan 2019, 15:29
If you received a CD then you have also the license in there. You have to call the setup directly, so that it can find the license file (copy both files to the desktop or other folder in your PC). So, remove the PCAN-RP1210 and install it again. If you still has problem with this, then contact us per mail, support[at]peak-system.com, and we will give you a tool for system checking.
