CCP_SelectCalibrationDataPage bug
A free API for the Communication with Control Units based on the CAN Calibration Protocol (CCP) by ASAM for Windows®
p.caruzzo
Post by p.caruzzo » Thu 21. Jun 2018, 15:08
Hi
I'm trying to send Select Calibration Data Page according to CCP Std 2.1 where Command Code = SELECT_CAL_PAGE 0x11;
using CCP_SelectCalibrationDataPage function available in PCCP.dll, unlucky the command code is 0x05, instead 0x11.
PCCP.dll is the last 32bit dll version dll available online on PEAK website.
Is any workaround to fix this issue?
Paolo
Re: CCP_SelectCalibrationDataPage bug
Post by K.Wagner » Thu 21. Jun 2018, 15:15
yes, I can confirm this is a bug. Please contact our support (support[at]peak-system.com) referring to this post. We will then give you a test-Version with a fix.
Thanks for bringing this to our attention!
p.caruzzo
Post by p.caruzzo » Thu 21. Jun 2018, 15:32
Thx for your quickly reply.
I sent u a mail as required.
Paolo
Post by K.Wagner » Thu 21. Jun 2018, 15:48
New version is on the way. we will appreciate a feedback, that the problem was solved with this test version. We will release this version in the near future.
Thanks in advance
Post by K.Wagner » Fri 22. Jun 2018, 08:11
Bug was fixed. Closed.
