One of the products I need to communicate via LIN requires a 14 byte message, is the PLIN API able to handle this in some way?
Also, when I attempt to send a frame ID of 172, only the synch and 172 are sent none of the data bytes are sent. The full message is as follows:
Frame ID: 172
Data bytes: 230 3 252 0 64
Any help on either of these is appreciated.
PLIN API Limitations
Re: PLIN API Limitations
it is not possible to send 14bytes with a single LIN messsage (max 8bytes per message). All those >8bytes transfers will be handled by multiple messages using a protocol like ISO-TP etc.
So it will be no problem to use our PLIN API to handle such a protocol in your application.
Regarding your LIN ID 172: this is not a valid LIN ID. A LIN ID is between 0x00 and 0x3F, even when interpreting this 172 as a PID, it is not a valid PID for LIN.
Please contact the manufacturer of your LIN system and ask for a LDF file, to get more information about the used system
