I have a PLIN hardware use I want to use as a Master and a pcb used as Slave.
I'm trying to use the APIs to send a diagnostic frame and also receive the response from the slave.
I made the following steps:
Checking the HW available. [using LIN_GetAvailableHardware]
Client registration. [using LIN_RegisterClient]
Client connection. [using LIN_ConnectClient]
Check the LIN bus. (Active) [using LIN_GetStatus]
Schedule a SlaveResponse slot with FrameId[0] = 0x3D [using LIN_SetSchedule]
Start the schedule slot. [using LIN_StartSchedule]
Write the message. -> Working, checked on the slave side. [using LIN_write]
But when I'm trying to read the response I never receive the correct response and usually I receive CC values.. [using LIN_read]
What I'm doing wrong?
Thanks!
