EDIT: Looks like it's only a problem on FrameID 0..7. Other IDs seem to produce correct lengths. I also removed the TLNFrameEntry code.
I am having difficulty with the LIN API. Steps I am using to send a LIN message:
1) Initialize (register, connect)
2) Iterate TLINFrameEntry and initialize correct lengths:
frmData.frameId = i
LIN_GetFrameEntry
frmData.ChecksumType = cstClassic;
frmData.Direction = dirPublisher;
-- really don't know what I'm doing with flags...
frmData.Flags = FRAME_FLAG_RESPONSE_ENABLE | FRAME_FLAG_SINGLE_SHOT;
frmData.Length = xxx;
LIN_SetFrameEntry
3) Create a msg:
TLINMsg msg;
TLINRcvMsg msgrx;
memset(&msg,0,sizeof(msg));
msg.Checksum = 0;
msg.ChecksumType = cstClassic;
msg.Direction = dirPublisher;
msg.FrameId = i;
msg.Data[0] = 1;
msg.Data[1] = 2;
msg.Length = xxx;
msg->FrameId |= parity<<6;
LIN_Write (device->client,device->handle,msg);
The result when captured by scope is a message (3 bytes long) that contains:
1) Break (edit - correction: FRAME)
2) Sync
3) protected ID/frame ID (with parity)
NOTE: Data and checksum are missing.
All return values are checked and are OK.
I'm new to LIN so I pretty much have no idea what I'm doing so your support will be helpful.
Trouble with LIN API
Re: Trouble with LIN API
Oops - there's also a call to LIN_CalculateChecksum(msg) during the write process.
And the device is configured as a master.
rc = LIN_InitializeHardware (device->client, device->handle, modMaster, device->config.baud);
It doesn't seem to matter which flags I set too. I've tried a few combinations.
It appears that the frame data is redundant/not used when the LIN_Write API is used. This is my reading from the PLIN API docs.
Verified using HWStatus that it is configured as a Master.
PLIn View (sample app) does work as expected using the same config (as far as I can tell).
When configured for 8 bytes, write each value from 0 to 64 (as a test)...
Message ID 0 through 7 don't push the data. Is this some magic LIN stuff that I'm not aware of? I was trying to replicate signalling I captured from the 'good' case.
Hello brfoster,
Please start reading the documentation. The file "PLIN API Documentation" (file: PLIN_enu.chm) contains a section dedicated to get familiarized with standard procedures within the PLIN API LIN as programming a LIN Master:
If you don't know what you are doing it will difficult for us to help you with it. The PLIN-API lets you communicate using the LIN protocol, but you have to get familiarized with the LIN protocol first.brfoster wrote:I'm new to LIN so I pretty much have no idea what I'm doing so your support will be helpful.
If I'm understanding well, you only want to program a LIN Master, for single messages writing from your application to the LIN network. The easy way is to use the LIN_Write function. The Frame entries are used to configure the LIN Table of a LIN Master/Slave. A LIN Table determines the way how the hardware behaves according to how it was initialized. For a Master, it represents the information used when its schedule is active, for the slave represents the behavior when a LIN Master sends a header to it.brfoster wrote:2) Iterate TLINFrameEntry and initialize correct lengths:
frmData.frameId = i
LIN_GetFrameEntry
LIN_SetFrameEntry
Use the function LIN_GetPID (Get parity ID) in order to determine the parity bits of the ID.brfoster wrote:msg->FrameId |= parity<<6;
brfoster wrote:It doesn't seem to matter which flags I set too. I've tried a few combinations.
there are flags that only works on slaves ... and you are programming a Master.brfoster wrote:frmData.Flags = FRAME_FLAG_RESPONSE_ENABLE | FRAME_FLAG_SINGLE_SHOT;
