In the PCAN-XCP API are provided the PXCP.dll files.
I am using the C++ Builder and for some reason I can not load the library. I assume that the library was created in Microsoft Visual C++.
Is it possible to get the dll files in order to use them with C++ Builder?
Best regards
Load PXCP.dll in C++ Builder
Re: Load PXCP.dll in C++ Builder
we have to check the DLL on this regard. It could be that indeed it has some incompatibility regarding C++ Builder (byte alignment for example). Meanwhile you can try to use the library with static load by using the PXCP.lib attached to this post.
- PXCP.zip
- Library for static linking of PXCP.dll
- (1.94 KiB) Downloaded 283 times
