I installed latest PCAN package from PEAK system web site (I don't know the version. It is not displayed in setup). I have PCAN PRO FD hardware and I want to set nominal and data phase bit rates.
It is not possible in my PC (see pcan_connect1.PNG).
It is possible in my friend's PC (see pcan_connect2.PNG).
Maybe it is related to the driver version. I see that driver version is old in my PC (2.48.3) (see driver.png). It is "4.0.18" in my friend's PC.
Do you have any idea why I can not set CAN-FD data bit rate?
I also want to remove all PEAK drivers and I want a clean start. But PEAK drivers are still there even after uninstall.
Murat
CAN-FD Data phase bit rate in PCAN View
- Driver version is "2.48.3" in my PC for CAN PRO FD. It is "4.0.18" in friend's PC.
- driver.png (12.16 KiB) Viewed 8926 times
- It is possible to see data bit rate in friend's PC
- pcan_connect2.PNG (43.5 KiB) Viewed 8926 times
- It is not possible to see data bit rate in my PC
- pcan_connect1.PNG (44.17 KiB) Viewed 8926 times
Re: CAN-FD Data phase bit rate in PCAN View
Please uninstall the PeakOemDrv Driver Setup from your PC (2.x is very old!) download the latest PCAN-USB Package from our Support Page and install the driver and the PCAN-View Software Tool.
The CAN-FD Features are available only in drivers 4.x or newer.
I believe this is a bug of PCAN view. I have never installed PCAN driver "2.48.3". When I click on "2.48.3", newly opened window displays PCAN driver correct (see attached image).
I'm using latest PCAN View (4.1.1.463).
I tried several PCAN drivers ("4.1.0.16057" or "4.1.1.16099"). No change.
Same problem exists in many of my collegues. We cannot set data phase bit-rate using PCAN view.
By the way, I can set nominal/data bit rates programatically correct.
Murat
Murat
- version_conflict.png (35.21 KiB) Viewed 8914 times
Please reboot your system after you have update the driver, and try again.
