Update PCAN-USB Pro FD from Firmware Version 1.x or 2.x to 3.x
CAN FD and LIN Interface for High-Speed USB 2.0
U.Wilhelm
Post by U.Wilhelm » Mon 23. May 2022, 11:16
If you own a first Generation PCAN-USB Pro FD and like to use the latest Firmware 3.x, you need to be sure that you bring your system up to date with some special Tools.
Since Firmware 3.x we have add a new Bootloader and you could update your PCAN-USB Pro FD very simple with our PEAK-Flash Tool --> link. This Tool includes always the latest Firmware vor nearly all PEAK-System CAN/LIN Devices.
If you own a PCAN-USB Pro FD with a Firmware 1.x or 2.x please follow this Steps:
Download the needed Bootloader Firmware and Documentation how to flash older Devices with the new Bootloader from this link.
or check this page: https://www.peak-system.com/produktcd/
Please read the Documentation and follow the steps as explained.
To flash the MSD-Bootloader to the Device, you need to use a Windows 8.1 or Windows 7 System :!:
W10 / W11 is not supported by this old Tools.
When your PCAN-USB Pro FD have once a Firmware >=3.x, you could use the PEAK-Flash Tool to bring it very simple up to date
Gabriel Guilbert
Re: Update PCAN-USB Pro FD from Firmware Version 1.x or 2.x to 3.x
Post by Gabriel Guilbert » Wed 21. Dec 2022, 19:03
Hi, looking to update the firmware of my device. Is support for updating the device under Windows 10 planned?
U.Wilhelm
Post by U.Wilhelm » Thu 22. Dec 2022, 09:23
The older Firmware can only be update on a W7 System - this is a restriction of W10/W11 not from us.
As the Firmware update was released at a time where mots peolple use a W7/8.1 we do not invest more time in change the Update Tool, to fix a W10/W11 limitation.
This is also simply not possible, because of the used USB Base stack in W10/W11. If this was simply to implement we already have done it....
