Hello everyone, I'm very tender and i started with the UDS protocol. The project that I have in mind, is to establish a session with a digital tachograph that canbus connects to the ECU master. The problem is that I'm repeatedly seeing the message "NO UDS RESPONSE" Although if I can read the canbus traffic perfectly.
(64-bit dlls are in right place, System32)
https://www.peak-system.com/forum/viewt ... t=SYSWOW64
(and after 2 months trying in different ways I can not see where I'm wrong)
the UDS messages I get are these:
02 10 02
Sends a Physical TesterPresent Message with no positive response :
UDS_SvcTesterPresent: 7
UDS request from 0xf1 (to 0x01, with RA 0x00) - result: 0 - OK !
\-> Length: 2, Data= 3e 80
Press <Enter> to continue...
02 3e 80
*** UDS Service: ReadMemoryByAddress ***
Sends a Physical ReadMemoryByAddress Message:
UDS_SvcReadMemoryByAddress: -2147483648
UDS request from 0xf1 (to 0x01, with RA 0x00) - result: 2 - ERROR !!!
\-> Length: 15, Data= 23 3a 41 42 43 44 45 46 47 48 49 4a 31 32 33
/!\ ERROR : NO UDS RESPONSE !!
Anyone have any ideas to get out of this strike?
thanks in advance
I can't establish a UDS session with a Digital Tachograph
Re: I can't establish a UDS session with a Digital Tachograp
We only could provide the Tools, but not the final solution. Please contact the ECU/Tachograph manufacturer. Only they could answer for your question. Maybe they use differnet Keys/Checksumms or have any other protection...
To check if the CAN Frames itself will be send / receive try PCAN-View first, then use a PCAN-Basic API (CAN Layer 2 Sample).You also could try to detect the OBD-II communication on the CAR/Vehicle to see if the unit reply. A full working sample OBD-II scanner is part of our free Tools.
Thanks a lot.
To rule out I tried with my car and I have the same problem, I can't establish a UDS session.
The question I have is if I need to connect to the ground of pin 3 and 6 of the DB9 connection, since only by connecting pin 2 of (CAN-L) and 7 of (CAN-H), I can already visualize the canbus traffic.
Are ground pins 3 and 6 necessary on the OBD connection, for UDS session ?
Sincerely
Pin assignment D-Sub
Pin Pin assignment
1 Not connected / optional +5V
2 CAN-L
3 GND
4 Not connected
5 Not connected
6 GND
7 CAN-H
8 Not connected
9 Not connected / optional +5V
Sincerely
Pin Pin assignment
2 CAN-L
3 GND
4 Not connected
5 Not connected
6 GND
7 CAN-H
8 Not connected
Normally you only need CAN-H and CAN-L on a High Speed CAN (ISO 11898-2).
To be sure that the ommunication work, simply use the PCAN-View to check if the Basic Layer 2 Communication works before try to run a UDS High Layer Session.
