Use the max 10Hz for GPS
Programmable Sensor Module with CAN Connection
Post by PEAK-Support » Tue 7. Mar 2017, 12:32
We often get the request if we could send the GPS Information on the CAN Bus in a frequenzy of 10Hz (the sample code provide only 1Hz) Attached a simple project which send out on 500K CAN Bus the GPS information in a frequenzy of 10Hz (this is the max that is possible from the uBlox unit)
example_10Hz.zip
10Hz GPS Sample
(132.68 KiB) Downloaded 6274 times
