Hotfix for Yagarto under Windows 8.1 / Windows 10
Programmable Sensor Module with CAN Connection
M.Gerber
Design & Documentation
Post by M.Gerber » Wed 31. Jul 2019, 16:00
Hi!
When compiling firmware examples or own firmware with the provided Yagarto tool chain ("make" command), you might encounter problems under Windows 8.1 and Windows 10. These can be:
  • One or several application error windows pop up describing a problem with rm.exe or other executable tools.
  • The make process terminates abnormally with text chunks like:
    • "No such file or directory"
    • "Resource temporarily unavailable"
    • "compilation terminated"
    • "make: *** [file.name] Error xy"
For a solution, please look at the corresponding thread (PCAN-Router section).
Greetings
Mark
** Edit Nov.2020 **
This Articel is no longer needed - please always use the ARM-Developer Packate from our Support side - we stop supporting the Yagarto Tool.
You could easy port your exeisting project to the new Toolset
