About macro
Ryans
About macro
Post by Ryans » Fri 17. Sep 2021, 11:12
Hello there,
Please find the attachment in this post.
I tried to make a macro file to send CAN message simply.
But, It doesn't seem to work my macro with "Waitdata function".
What should I check for it?
Thank you in advance.
XImage 404.png (18.81 KiB) Viewed 1590 times
Re: About macro
Post by M.Heidemann » Fri 17. Sep 2021, 13:07
You seem to have missed the length parameter, the standard macro needs
to know how long the message actually is:
Your incoming message is actually 8 Bytes long and you will have to
specify this appropiately, your current macro actually waits for:
| WaitData | Time | Bus | CAN-ID | Length |  DataBytes  |
|        - |    0 |   1 | 0x7DFh |      2 | 0x10h 0x81h |
however to wait for the actual message shown in your screenshot, you macro would look like this
WaitData 0 1 7DFh 8 02h 10h 81h 55h 55h 55h 55h 55h
To actually represent the message your are waiting for:
|        - |    0 |   1 | 0x7DFh |      8 | 0x02h 0x10h 0x81h 0x55h 0x55h 0x55h 0x55h 0x55h |
If you only want to check the first 3 bytes, you still need to give the actual length, but you can
use wildcards isntead of actual values for bytes you do not care about:
WaitData 0 1 7DFh 8 02h 10h 81h * * * * *
Please let us know if you were able to solve this using the provided information.
Ryans
Re: About macro
Post by Ryans » Fri 17. Sep 2021, 13:51
Many thanks
I will try to do it again.
