Adding VB Scripts automatically when opening PCAN Explorer project.
cpacileo
Re: Adding VB Scripts automatically when opening PCAN Explorer project.
Post by cpacileo » Tue 30. Apr 2024, 14:51
Alright, I figured it out...
Sub LoadMyRoutine()
	Dim myScript
	For Each myScript In VBSMacroFiles
		If myScript.DisplayName = "pemScriptFileName" Then _
			myScript.IsEnabled = True
	Next
	PrintToOutputWindow "Scripts automatically loaded"
End Sub
Thank you for trading ideas with me, Marvin.
Post by M.Heidemann » Tue 30. Apr 2024, 15:00
That's another way to do this, yeah.
By default you shouldn't have to do this however, this should already be the case once you load the project.
Hence why i proposed checking how a fresh file will handle. However, if you are satisifed with the solution
as it is, i am satisified as well.
cpacileo
Post by cpacileo » Tue 30. Apr 2024, 15:04
Yea it is very strange. The weirdest part is that I have another pem file in the SAME directory with the SAME permissions and it gets loaded just fine on its own. Your suggestion might also work by just making another file but in the future it could be corrupted again and therefore my scripts will ensure no matter what it will work.
Post by M.Heidemann » Tue 30. Apr 2024, 15:10
one last suspicion regarding this on my end.
If it's not already the case, please see if you can update PCAN-Explorer 6 to the latest version (6.7.0),
via "Help" -> "Check for Updates":
If this does not work (Due to comapy it policy etc) just contact
us via mail with your license-id and we will get you up to date ;)
