UI with VBScript Macro or Strandard Macro
Re: UI with VBScript Macro or Strandard Macro
Post by M.Heidemann » Fri 19. Apr 2024, 14:50
To add to this, some information from our development-team:
the stack overflow is correct, as it recursively calls Call SendParameters again and again and each time a return address is placed on the internal stack.
At the end of the "subroutine" called with Call, it uses "Repeat", whereby the macro jumps back to the beginning and calls Call again. And again and again...
Instead of "Repeat", one must call "Return" at the end of his subroutine, then the stack is also reduced.
To repeat everything, "Repeat" needs to come directly after Call. A branch or another return must also be placed there, otherwise the program would run back into the code of the subroutine after the return from Call.
epignosi
Post by epignosi » Tue 23. Apr 2024, 09:07
It is working very well if I don't use a label.
Thank you.
Post by M.Heidemann » Tue 23. Apr 2024, 09:09
thank you for letting us know!
- closed -
