How can I read a value from an "Edit Value" field in my Instrument panel using a Sub in the VBS Macro File ?
Thanks!
Read UI element using VBS marco
Re: Read UI element using VBS marco
There is an example in the Instruments-Panel help:
You'll find more info on IP-elements under reference.
Sub ValueEditValueExample()
Dim panel, valEdit
Set panel = Documents("MyPanel.ipf").ActiveWindow.Object
Set valEdit = panel.Scenes(1).Controls("ValueEdit1")
MsgBox "Value = " & valEdit.Value
End Sub
