I would like to know how to open an additional Scene2 when pressing a Button during the operation of the main Scene in PCAN Explorer's Instrument Panel.
It seems like using a macro would work. I tried finding the method in the Help by pressing F1, but it only explains how to add a completely new scene, not how to open an existing Scene2 that has already been created.
Thank you for your assistance.
Best regards
How to open an additional scene from the main scene?
CheolsoonKwon
Re: How to open an additional scene from the main scene?
Please send us a E-mail to support[at]peak-system.com we will send you a sample project that shows how to switch between different scenes in a panel in VBS.
Please also add your PE6 license number to the E-mail (please do not post such infos here in public)
As a simple info up in front see this script:
So switching between different Scenes could be done by script (" panel.Scenes.Item(X).IsActive = true") or in the Panel Property by simply change a Signal Value:
' Get Panel Referenze
Set panel = Documents("Scene_Object_Sample.ipf").ActiveWindow.Object
' Set the current active scene to a variable
Set activescene = panel.ActiveScene
PrintToOutputWindow("Active is " + activescene)
' Is scene 1 active - if not set scene 1 active
if activescene.Index <> 1 then
PrintToOutputWindow("Set Scene 1 to active")
panel.Scenes.Item(1).IsActive = true
end if--------------------------------
