Unable to use PCAN-USB X6 with SocketCAN under Linux
6-Channel CAN FD Interface for High-Speed USB 2.0
altran
Post by altran » Wed 22. Feb 2017, 23:11
Is this device supported for use with the Linux SocketCAN drivers?
Re: Unable to use PCAN-USB X6 with SocketCAN under Linux
Post by M.Maidhof » Thu 23. Feb 2017, 11:35
yes, it will be supported with kernel Version 4.9 or higher. If you use an older kernel you have to install our peak-linux-driver 8.3.1 and compile it for NetDev support, or install an out-of-tree kernel driver for the PCAN-USB-X6.
