I have some strange problems with miniPCIe (PCAN-miniPCIe FD) on Linux and SocketCAN. I use the card with four channels in an PCEngines APU (apu4: https://pcengines.ch/apu4d4.htm). I have tested it with three different CAN devices, and I see the same problem on all. I can read without problems, but when writing I get "No buffer space available" (err=105). After the error is triggered the interface freezes completely and reading is also blocked.
The interesting thing is that when I use PCAN-USB interfaces instead (drop-in replacement) it works perfectly (same computer, same OS, same software), even when running two such interfaces simultaneously. I also tried with two different new APU units, as well as two different PCAN-miniPCIe FD devices, with the same results. Therefore I think it might relate to either the miniPCIe hardware implementation on the APU, or the Linux peak_pciefd (while the peak_usb works fine). Or might it be something related to the "FD", as the PCAN-USB did not have any flexible data? Could I get some help to debug this?
I saw some suggestions for kernel parameters, but I didn't test anything yet as I would first want to understand what is going on.
Perhaps this is related? viewtopic.php?f=144&t=3354&p=10055&hili ... upt#p10055
$ uname -a
Linux seacat-0 6.0.11-arch1-1 #1 SMP PREEMPT_DYNAMIC Fri, 02 Dec 2022 17:25:31 +0000 x86_64 GNU/LinuxCode: Select all
# dmesg | grep pci
[ 6.199217] peak_pciefd 0000:05:00.0: 4x CAN-FD PCAN-PCIe FPGA v3.2.1:
[ 6.200628] peak_pciefd 0000:05:00.0: can0 at reg_base=0x000000006f2e9645 irq=64
[ 6.201440] peak_pciefd 0000:05:00.0: can1 at reg_base=0x00000000ac7722b2 irq=64
[ 6.205225] peak_pciefd 0000:05:00.0: can2 at reg_base=0x0000000032cddb9f irq=64
[ 6.206277] peak_pciefd 0000:05:00.0: can3 at reg_base=0x0000000028aac725 irq=64Code: Select all
# cat /proc/interrupts
CPU0 CPU1 CPU2 CPU3
0: 51 0 0 0 IO-APIC 2-edge timer
4: 0 0 0 18 IO-APIC 4-edge ttyS0
7: 0 0 0 0 IO-APIC 7-fasteoi pinctrl_amd
8: 0 0 1 0 IO-APIC 8-edge rtc0
9: 0 0 0 0 IO-APIC 9-fasteoi acpi
16: 0 0 0 0 IO-APIC 16-fasteoi mmc0
18: 0 3504036 0 0 IO-APIC 18-fasteoi ehci_hcd:usb1, ehci_hcd:usb2
19: 76599 0 0 0 IO-APIC 19-fasteoi ahci[0000:00:11.0]
25: 0 0 0 0 PCI-MSI 34816-edge PCIe PME, aerdrv
27: 0 0 0 0 PCI-MSI 36864-edge PCIe PME, aerdrv
29: 0 0 0 0 PCI-MSI 38912-edge PCIe PME, aerdrv
31: 0 0 0 0 PCI-MSI 40960-edge PCIe PME, aerdrv
32: 0 0 0 0 PCI-MSI 43008-edge PCIe PME, aerdrv
33: 0 0 0 0 amd_gpio 89 switch1
34: 49755036 0 0 0 PCI-MSI 262144-edge xhci_hcd
35: 0 0 0 0 PCI-MSI 262145-edge xhci_hcd
36: 0 0 0 0 PCI-MSI 262146-edge xhci_hcd
37: 0 0 0 0 PCI-MSI 262147-edge xhci_hcd
38: 0 0 0 0 PCI-MSI 262148-edge xhci_hcd
39: 0 1 0 0 PCI-MSI 524288-edge enp1s0
40: 0 0 529638 0 PCI-MSI 524289-edge enp1s0-rx-0
41: 0 0 0 112652 PCI-MSI 524290-edge enp1s0-rx-1
42: 127204 0 0 0 PCI-MSI 524291-edge enp1s0-tx-0
43: 0 48789 0 0 PCI-MSI 524292-edge enp1s0-tx-1
45: 3 0 0 0 PCI-MSI 1048576-edge enp2s0
46: 0 385302 0 0 PCI-MSI 1048577-edge enp2s0-rx-0
47: 0 0 47336 0 PCI-MSI 1048578-edge enp2s0-rx-1
48: 0 0 0 46306 PCI-MSI 1048579-edge enp2s0-tx-0
49: 100927 0 0 0 PCI-MSI 1048580-edge enp2s0-tx-1
57: 0 0 0 0 PCI-MSI 131073-edge ccp-1
59: 0 0 0 0 PCI-MSI 2097152-edge enp4s0
60: 45273 0 0 0 PCI-MSI 2097153-edge enp4s0-rx-0
61: 0 45273 0 0 PCI-MSI 2097154-edge enp4s0-rx-1
62: 0 0 45273 0 PCI-MSI 2097155-edge enp4s0-tx-0
63: 0 0 0 45273 PCI-MSI 2097156-edge enp4s0-tx-1
64: 0 0 1293332 0 IO-APIC 16-fasteoi peak_pciefd, peak_pciefd
NMI: 490 266 262 258 Non-maskable interrupts
LOC: 19473766 15957702 14736671 14823410 Local timer interrupts
SPU: 0 0 0 0 Spurious interrupts
PMI: 490 266 262 258 Performance monitoring interrupts
IWI: 2 3 0 3 IRQ work interrupts
RTR: 0 0 0 0 APIC ICR read retries
RES: 860307 875618 862165 846639 Rescheduling interrupts
CAL: 6078259 5873478 5880196 5806704 Function call interrupts
TLB: 7020 6739 6216 6168 TLB shootdowns
TRM: 0 0 0 0 Thermal event interrupts
THR: 0 0 0 0 Threshold APIC interrupts
DFR: 0 0 0 0 Deferred Error APIC interrupts
MCE: 0 0 0 0 Machine check exceptions
MCP: 291 291 291 291 Machine check polls
ERR: 1
MIS: 0
PIN: 0 0 0 0 Posted-interrupt notification event
NPI: 0 0 0 0 Nested posted-interrupt event
PIW: 0 0 0 0 Posted-interrupt wakeup eventCode: Select all
ip link set can0 up type can bitrate 250000
