what are the settings for a standard RS232 terminal communication with PCAN-LIN module?
documentation deals with 38400bauds (as default value) but nothingt about parity or data length.
RS232 settings for communication to PCAN-LIN
Re: RS232 settings for communication to PCAN-LIN
default values are: 38400,8,N,1
OK, I configure the terminal this way and have nothing displayed.
- config_Master_Siège.pclin
- configuration file of the module I'm connected to for RS232 spy function
- (43.23 KiB) Downloaded 243 times
what do you like to see? You didn´t configure a LIN forwarding to RS232.
Quite sur I did, but may be not saved the right way.
Now I've the configuration from attached picture and see, on "Messages and Scheduler" section, information. I continue setting my configuration. Thanks for your support.
- Capture.JPG (12.21 KiB) Viewed 1719 times
