Clearing "Messages and Scheduler" tab
RS-232 to CAN/LIN Interface
R1MARC
Post by R1MARC » Wed 28. Nov 2018, 12:19
Is there a simple way to clear the "Messages and Scheduler" tab in PCAN-LIN CT application?
I still have messages from tests before I changed configuration (of gateway and/or cables on the system): it is a polution of the screen, making view of usefull data difficult.
One solution is to close the application, restart it, reconfigure it (including RS232 port) and so on: quite long!
Is a simple button "clear display" somewhere?
Re: Clearing "Messages and Scheduler" tab
Post by K.Wagner » Wed 28. Nov 2018, 12:24
there is a "Clear button" in the lower right corner of the "Messages and Scheduler" tab. Try clicking it.
R1MARC
Post by R1MARC » Wed 28. Nov 2018, 12:57
too far on the right when you have a wide screen and application in full screen mode
Post by K.Wagner » Wed 28. Nov 2018, 13:28
In each tab, the default button is always right aligned. It is also triggered when hitting the "Return/Enter" key.
This is also described in the help file (can be read in any resolution).
PCAN-LIN CT Help file
PCAN-LIN CT.PNG (32.57 KiB) Viewed 1639 times
R1MARC
Post by R1MARC » Wed 28. Nov 2018, 15:43
thanks for the tip, including clearing by double click in the window
