Identifying several PCAN-LIN on a PC
Posted: Wed 28. Nov 2018, 13:53
I've 2 PCAN-LIN attached to my laptop, through USB-RS232 converter, and then 2 PCAN-LIN CT application.
Is there a way to identify which instance of application goes to which gateway?
The COM port at the bottom of the window can change from one connection to another (USB rules) and, sometimes,bateways are moved from an adapter to the other, crossing the configuration on application.
