Can not control LIN slave devices from CAN messages
RS-232 to CAN/LIN Interface
AbelOverride
Post by AbelOverride » Wed 18. Sep 2019, 15:19
I'm trying to manage two LIN latches with two CAN messages.
The feedback messages are ok but when I'm trying to control the latches, the latches don't follow the commands...
I think I have the correct schedule time and publisher and subscriber ID's.
Thanks for your help.
CAN_LIN_gateway_feedback_working_v002.pclin
(43.57 KiB) Downloaded 104 times
Re: Can not control LIN slave devices from CAN messages
Post by M.Maidhof » Wed 18. Sep 2019, 15:54
what kind of CAN messages did you send to the PCAN-LIN? Please note that you have to use an offset of 0x40 for the CAN ID to change the publisher data. In your case you have to send a CAN ID 0x04 +0x40 +CAN-ID Offset (in your case 0x48E) = 0x4D2 with dlc 2 to change the publisher data of LIN ID 0x04.
AbelOverride
Post by AbelOverride » Wed 18. Sep 2019, 17:00
Hi Michael,
Yes, I did it and that's not the problem. I think the problem is with the timing or the counter... With direct LIN messages, my configuration is working fine but when I add the PCAN-LIN... The latches are not following my commands...
The frame configuration is OK and the scheduler also.It Is following the .ldf table...
Any other idea?
Thanks a lot!
Abel.
Post by M.Maidhof » Thu 19. Sep 2019, 09:16
do you have a ldf of your LIN system, to see the length code and checksum type of the used LIN frames?
AbelOverride
Post by AbelOverride » Thu 19. Sep 2019, 11:01
Hi Michael,
Yes! Take a look:
What do you think? I'm going to record a log with PLIN.
Abel.
Post by M.Maidhof » Thu 19. Sep 2019, 15:54
unfortunately I can't see any baudrate settings in your screenshot. Please be sure that you disable the publisher from your other LIN device, while using PCAN-LIN. It is not possible that there are two devices setting the same publisher data.
AbelOverride
Post by AbelOverride » Thu 19. Sep 2019, 16:31
Hi Michael,
Baudrate is 19.200 Kbps.
I only have one Master device (PCAN-LIN) and two slave devices. Please, take a look to the log with PLIN-USB.
I do not know why PCAN-LIN is not working...
Thanks again!
Abel.
PLIN_log_VECTOR_PCAN_LIN_not_working_ok.ltrc
(200.09 KiB) Downloaded 97 times
Post by M.Maidhof » Thu 19. Sep 2019, 17:18
do you have a ldf of that system, to see which frames are publisher and which are subscriber. This is not clear for me from your screenshots.
AbelOverride
Post by AbelOverride » Fri 20. Sep 2019, 08:14
Hi Michael,
Please find attached the ldf file.
Thank you!
Abel.
PCL_2door_SecurityLIN_Rel5_2_CONV_FULL.ldf
(7.43 KiB) Downloaded 101 times
Post by M.Maidhof » Mon 23. Sep 2019, 11:30
your configuration looks ok. Can you please contact me by phone or email (use our support email address) to check your setup again. Thank you.
