attached you will find a pdf document showing you typical LIN applications, which you can handle with the PCAN-LIN module:
- Using PCAN-LIN as LIN/CAN/Serial gateway as a simple LIN listener.
- Using PCAN-LIN as LIN Master using the internal Scheduler of PCAN-LIN.
- Using PCAN-LIN as LIN Master controlled by serial streams.
- Using PCAN-LIN as LIN Master controlled by CAN frames.
There are much more LIN applications possible with the PCAN-LIN device, but those 4 are the most frequently used scenarios we will get as feedback in our support area.
