I want to read a Voltage from the Analog In 1 Pin and output that Voltage in a CAN message.
How do I do this using the PCAN Router Pro FD?
Tim
Read Voltage from Analog In
Re: Read Voltage from Analog In
if you take a look into the Sample 08_HW_IO and check in the main.c / line 120 , you will find this code
The AD have 12Bit, and the Result is 8.13mV per Digit.
We will extend this in the next Version to an own Function like the DIn.
// clear EOC flag by read the ADC2 register
TempVar = ADC2->DR & 0xFFF;
ADC2->SQR3 = 6;
ADC2->CR2 |= 1 << 30;
// wait EOC flag
while ( !( ADC2->SR & ( 1 << 1)))
ResultData = ADC2->DR & 0xFFF;
We have add the HW_GetAIN to the code - so now you simply call the function to get the Analogue value.
Here a sample - CAN ID 0x55A / STD Msg, trigger the function and send the result on 0x55B in the first 16 Bits (Byte 0 and 1)
Here the new Block in "hardware.h"
uint32_t tmp32;
// catch ID 55Ah to send analog value from AIN
if ( RxMsg.id == 0x55A && RxMsg.msgtype == CAN_MSGTYPE_STANDARD)
HW_GetAIN ( &tmp32);
RxMsg.id = RxMsg.id + 1;
RxMsg.data16[0] = tmp32;
CAN_Write ( CAN_BUS1, &RxMsg);
//! @brief get AIN from I/O pins
//! @param buffer result buffer (single uint32_t)
//! @return one error of HW_ERR_...
HWResult_t HW_GetAIN ( uint32_t *buffer);
//! @brief
//! Read digital inputs. Each bit will represent a digital pin.
//! @param buffer Buffer for DIN-value
HWResult_t HW_GetDIN ( uint32_t *buffer);
//! @brief
//! Set digital outputs. Each bit will represent a digital pin.
//! @param buffer Buffer for DOUT-value
HWResult_t HW_SetDOUT ( uint32_t *buffer);
