Jakob
Post
by Jakob » Mon 19. Feb 2024, 12:44
Hello
I am trying to use the GPIO Pins as Output based on CAN Signals. I already did the CAN Message part but now I am stuck with the configuration of the Output. I downloaded the DevPack from [0] and found a function HW_GetDIN in hardware.c and also a HW_SetDOUT in hardware.h but there is no such function in hardware.c. From the HW_GetDIN-Function I assume that the GPIOS are connected to the pin 4,5,6, and 7 of the register K. However setting the Mode Register and the Ouput register
GPIOK->MODER |= 0x00005500;
GPIOK->ODR = GPIOK->ODR | 0x000000F0;
did not help. Can you please help?
Jakob
--- hardware.c ---------------------------------------------------------------
//! @brief get DINs 3...0 from I/O pins
//! @param[out] buffer result buffer (single uint32_t)
HWResult_t HW_GetDIN ( uint32_t *buffer)
if ( buffer == NULL)
{ return HW_ERR_ILLPARAMVAL;}
buffer[0] = (( GPIOK->IDR >> 4) & 0xF) ^ 0xF;
return HW_ERR_OK;
[0] link to WEB Page removed...
** ADMIN **
Post
by PEAK-Support » Mon 19. Feb 2024, 12:53
Please download the latest Package - we have add functions for all Digital / Analog Port(s) that we
officially support (part of the Connector - all other Pins should not be used !)
//! @brief get AIN from I/O pins
//! @param buffer result buffer (single uint32_t)
//! @return one error of HW_ERR_...
HWResult_t HW_GetAIN ( uint32_t *buffer);
//! @brief
//! Read digital inputs. Each bit will represent a digital pin.
//! @param buffer Buffer for DIN-value
HWResult_t HW_GetDIN ( uint32_t *buffer);
//! @brief
//! Set digital outputs. Each bit will represent a digital pin.
//! @param buffer Buffer for DOUT-value
HWResult_t HW_SetDOUT ( uint32_t *buffer);
If you need some Debug help, and therefor want to use the additional Pins, please check the Debug Folder of the Package.
There you find more information how to do a real single Step Debug via JTAG.
FYI- in the hardware.c file of the HW_IO Sample project, you find all functions as source code:
// clear EOC flag
buffer[0] = ADC2->DR & 0xFFF;
ADC2->SQR3 = 6;
ADC2->CR2 |= 1 << 30;
// wait EOC flag
while ( !( ADC2->SR & ( 1 << 1)))
// return raw value
return HW_ERR_OK;
return HW_ERR_OK;
//! @brief set DOUTs 3 ... 0 of the I/O pins
//! @param[in] buffer input buffer ( single uint32_t)
FPGA->SYS_DOUT_WR = buffer[0];
return HW_ERR_OK;
