How to set Douts in firmware
technick100
Post by technick100 » Mon 15. Apr 2024, 07:27
Could you please hel us.
We have PCAN-Router Pro FD.
Bootloader version: 2.0.11
Hardware Version 5
FPGA ver: 10
We downloaded the latest version of the developer's package and checked an example "08_HW_IO".
The problem is next....if we run this code
HWResult_t  HW_SetDOUT ( uint32_t  *buffer)
   if ( buffer == NULL)
	 { return HW_ERR_ILLPARAMVAL;}
   FPGA->SYS_DOUT_WR = buffer[0];
   return HW_ERR_OK;
uint32_t  tmp32 = 0xFFFF (or 0xFF);
// set DOUTs, all bits used
HW_SetDOUT ( &tmp32);
we receive 12 volts only on the first output, the other three outputs show 0 volts. How to set "logic 1" on another outputs?
0xFF is 0b11111111
we tried to use 0x0F, also no any effects.
Re: GPIO not work properly. Please Help!!!
Post by M.Heidemann » Mon 15. Apr 2024, 09:12
Please have a look at /inc/hardware.c
//! @brief
//! Set digital outputs. Each bit will represent a digital pin.
//! @param		buffer		Buffer for DOUT-value
//! @return		one error of HW_ERR_...
HWResult_t  HW_SetDOUT ( uint32_t  *buffer);
As well as example "08_HW_IO", /src/main.c
					// catch ID 334h to control DOUTs
					if ( RxMsg.id == 0x334  &&  RxMsg.msgtype == CAN_MSGTYPE_STANDARD)
                  uint32_t  tmp32;
                  tmp32 = RxMsg.data8[0];
						break;
					// catch ID 55Ah to send analog value from AIN
					if ( RxMsg.id == 0x55A  &&  RxMsg.msgtype == CAN_MSGTYPE_STANDARD)
                  uint32_t  tmp32;
Make sure you the example works as expected on your device, if so, you can proceed with your own implementation based on that.
technick100
Post by technick100 » Mon 15. Apr 2024, 09:24
Hello, Marvin
Thank you for your answer. I have read your response and I'll ask it in another way.
Our code and code from example almost same, my question is:
what value should be set inside RxMsg.data8[0] to get "logic 1" at all four digital outputs?
uint32_t  tmp32;
Post by M.Heidemann » Mon 15. Apr 2024, 10:33
Given we have 4 DOUTS and a 32bit buffer,
that means youll will need at least 4 bytes -> 0xffh 0xffh 0xffh 0xffh
MArvin
