Firmware Update for CAN-USB (2.0a/b) and PCIe FD Hardware
U.Wilhelm
Post by U.Wilhelm » Fri 8. Oct 2021, 14:05
PEAK-Flash Firmware Update Tool - 10/2021 B E T A
Requirements:
  • Windows 10 (minimum 19H2) 32 or 64 Bit
  • C++ Redistributable Package for Visual Studion (is part of the package)
Please note that this software contains firmware that has not yet been officially released.
For the already officially released firmware versions, please download the official PEAK-Flash application from our support page.
But all included Firmware Versions are well tested and will be released soon.
Please download the File - unzip and run the Tool in the Folder PEAK-Flash.
If the PEAK-Flash does not start - check if the needed C++ Redistributable Package is installed
(it is also part of the Package - Folder "C++_Redistributable")
** DOWNLOAD LINK PEAK-Flash BETA **
Firmware Update-BETA-Package_v1.4.0.zip
PEAK-Flash - BETA (USB 2.0a/b - PCIE CAN FD)
(19.65 MiB) Downloaded 95 times
Please NEVER Disconnect the Device or power off your PC when a Firmware Update is in progress. This could end up in a bricked device !
Historie / Changes
PCAN-USB CAN 2.0a/b Adapter
For the USB Devices the Firmware is depending to the used Hardware.
For Adapters of the 1st Generation the latest Firmware is the V5.3
For Adapters of the 2nd Generation the latest Firmware is the V8.6.1
PCAN-USB IPEH-002021, IPEH-002022 (Serial Number up to 190.000)
Update to Firmware V5.3
For this Update your system need minimum a Firmware version 2.8
* added Status info in case the RX or TX CAN Error counter decreases
* Selfreceive option added
* Bus-Power for some special Devices (OEM)
* some performance and features enhancements
PCAN-USB IPEH-002021, IPEH-002022 (Serial Number greater 200.000)
Update to Firmware V8.6.1
For this Update your system need minimum a Firmware version 8.2
* Added the reset of last error counters due to unexpected error counter frame after error recovery
PCAN-PCIe FD Interfaces
PCAN-PCIe FD based CAN Interfaces
PCAN-PCI Express FD IPEH-004026, IPEH-004027, IPEH-004040
PCAN-miniPCIe FD IPEH-004045, IPEH-004046, IPEH-004047
PCAN-PCI/104-Express FD IPEH-004080, IPEH-004081, IPEH-004082
PCAN-M.2 IPEH-004083, IPEH-004084, IPEH-004085
PCAN-Chip PCIe FD IPES-004092, IPES-004093
Update to Firmware V3.5.6
For this Update your system need minimum a Firmware version 3.2.1
* bugfix: malformed PCIe TLPs (mix of 32/64 bit DMA transactions => BSOD)
* sys_time (timestamp timer) readable on system (device) register block
* bugfix: suppress status frame during BUSOFF when leaving reset-mode
* option added: time-stamp option for start-of-frame
* option added: option to send ACK also as transmitter
* option added: option to ignore (tolerate) BRS frames as receiver
* bugfix: bad PCIe TLP length ( issue when busload frame is discarded => BSOD)
* PCIe IP Core 6.8 (official release for PCIe Gen 4 enumeration issue)
* CAN Core Gen 3 v5-1
* bugfix: CAN error generator
