Connection, but no data is sent
U.Wilhelm
Re: Connection, but no data is sent
Post by U.Wilhelm » Wed 12. Dec 2012, 14:00
If only the CAN Data is missing, maybe you need to check if CAN Data is available, baudrate is OK, Termination of CAN Bus is OK etc..
jwphrijk
Post by jwphrijk » Wed 12. Dec 2012, 17:35
The first issue is was indeed not beeing able to send A CAN message via PCAN explorer to the connected GPRS link.
But this was with the unsuporting server version. (1.2.1.73 )
A termination also isn't the problem because the route the message is suppost to travel is : PCAN-Explorer --> virtual CAN-net --> PCAN-server/cliënt --> TCP-IP GPRS connenction --> PCAN GPRS-Link client.
As you can see there is no use for cables.
After installing the correct server version (1.3.1.87) It doesn't even connect any more.
As far as I know the buadrate is only to concern of the virtual net. Aslong as it doesn't connect this should not make a difference.
U.Wilhelm
Post by U.Wilhelm » Thu 13. Dec 2012, 08:39
We go around in circles...please contact us via E-mail (you know the address), inkl. all Version informations of Software on PC and all LIB Versions you use on the PCAN-GPRS Link. If you changed source we also need the complete DIFF.
