pcan-light migration path
CAN Software API for Windows®. REGARD! This API is out-dated. Please use PCAN-Basic for new software developments.
Locked
MrBillDay
Post by MrBillDay » Wed 16. Oct 2019, 17:48
I have recently taken over support for an application that uses pcan_usb.dll. I did not write the original code. The pcan_usb.dll is unsigned. The application has one third-party dll that does not allow partially trusted callers. So relaxing trust on my application isn't an option.
I am looking for a migration from pcan_usb.dll to the recommended signed and supported replacement.
Thank you
Re: pcan-light migration path
Post by K.Wagner » Thu 17. Oct 2019, 08:38
the current API that you need to use is called PCAN-Basic. It is the successor of PCAN-Light and it supports CAN 2.0A/B and CAN with flexible data-rate (CAN-FD).
The way how it works is very similar to PCAN-Light; you need to initialize a PCAN channel before using it (CAN_Initialize, CAN_InitializeFD), then you have functions to read (CAN_Read, CAN_ReadFD) and write (CAN_Write, CAN_WriteFD), to adjust the filter (CAN_FilterMessages), to configure several parameters like Listen-Only (CAN_GetValue/CAN_SetValue), and to close a channel (CAN_Uninitialize).
The PCAN-Basic API is fee-free, it is accompanied by several sample projects in different programming languages (C#, VB.Net, C++/CLI, C++MFC, C+++ Builder, Delphi, Python) that show the use of all functions mentioned before. Added to this you get a CHM help file for the API, and a PDF documentation for about 40 parameters, that are currently supported by the CAN_GetValue/CAN_SetValue functions.
Also under this forum, PCAN-Basic, you will find many answer to problems that may arise while porting your code.
By the way, the PCAN-Basic API has also a Linux version. Applications written in Python, for instance, can work in both operating systems.
MrBillDay
Post by MrBillDay » Thu 17. Oct 2019, 14:05
Thank you so much for your help. This has been weighing on me for a while...I knew it was one of those nagging details that was unknown and could have caused me a lot of trouble.
Thanks again for your assistance.
Post by K.Wagner » Thu 17. Oct 2019, 16:42
you are welcome.
Closed.
Locked
