Measuring time with QPC
ValeVG
Post by ValeVG » Wed 10. Jun 2020, 16:01
I read some forum posts where you specify that you use QueryPerformanceCounter and QueryPerformanceFrequency to measure timestamps. I tried to do the same, but I get different timestamps. Which part am I doing wrong?
My code is:
send CAN frame and save current time point with code:
LARGE_INTEGER EndingTime, ElapsedMicroseconds;
        LARGE_INTEGER Frequency;
        QueryPerformanceFrequency(&Frequency);
        QueryPerformanceCounter(&EndingTime);
        ElapsedMicroseconds.QuadPart = (EndingTime.QuadPart * 1000000) / Frequency.QuadPart;
        cout << "time point: " << ElapsedMicroseconds.QuadPart << endl;
Then I get response message in couple milliseconds and I read its timestamp with code:
                r = pcan->Read(pcan->channel, &receivedMsg, &timestamp);
                if (r == PCAN_ERROR_OK)
                    microsTimestamp = timestamp.micros + 1000 * timestamp.millis + 0x100000000 * 1000 * timestamp.millis_overflow;
                cout << microsTimeStamp << endl;
Output looks like this:
time point: 202831938021
968478406
Which is wrong, even from the number of digits. I hope you can help me. :)
M.Gerber
Design & Documentation
Re: Measuring time with QPC
Post by M.Gerber » Thu 11. Jun 2020, 09:27
Hello ValeVG,
We have a holiday here in Germany, thus please be patient until the answer to your problem (anticipated tomorrow, Friday).
Mark
ValeVG
Post by ValeVG » Mon 15. Jun 2020, 07:39
Hello ValeVG,
Mark
Sure thing, enjoy your holidays. :)
Post by K.Wagner » Mon 15. Jun 2020, 08:56
As far as I can see, the value you are calculating is being truncated to a 32-bit value. Is microsTimestamp also a large integer? Please note that you have to do your operations using 64-bit variables.
ValeVG
Post by ValeVG » Mon 15. Jun 2020, 10:10
Sorry for not including whole code in first comment. It's defined as
long long int microsTimestamp;
If I do:
std::cout << "sizeof: "<< sizeof(microsTimestamp) << std::endl;
It prints
sizeof: 8
Post by K.Wagner » Mon 15. Jun 2020, 10:20
truncation can also occur, when in a calculation no type specification is done. Try the calculation like this:
    UINT64 micros = 0L;
    micros = UINT64(ts.millis) * 1000 + ts.micros + 0x100000000 * 1000 * ts.millis_overflow;
    return micros;
ValeVG
Post by ValeVG » Mon 15. Jun 2020, 10:42
Yes, that was it. I get similar timings now. Thank you for your help!
Post by K.Wagner » Mon 15. Jun 2020, 10:45
You're welcome. Closed
