Troubles getting channels count using Peak.Can.Basic in C#
Locked
hugues.ostermann
Post by hugues.ostermann » Mon 29. Jun 2020, 14:09
I have troubles getting the channel count using PCANBasic.GetValue method.
Return is always the following error -> TPCANStatus.PCAN_ERROR_ILLPARAMTYPE.
Sounds like I am not using the method properly.
However, I followed the sample code examples provided in documentation.
Any clue of what goes wrong here ?
            uint iChannelsCount;
            TPCANStatus stsResult;
            // preinitialize
            stsResult = PCANBasic.GetValue(PCANBasic.PCAN_NONEBUS, TPCANParameter.PCAN_ATTACHED_CHANNELS_COUNT, out iChannelsCount, sizeof(uint));
Re: Troubles getting channels count using Peak.Can.Basic in C#
Post by M.Heidemann » Mon 29. Jun 2020, 14:15
Which version of PCANBasic are your currently using?
hugues.ostermann
Post by hugues.ostermann » Mon 29. Jun 2020, 16:53
Using API version 1.2.1.31
Post by M.Heidemann » Tue 30. Jun 2020, 08:18
This parameter was introduced in version 4.4.0 of PCANBasic, make sure to switch to
the current version of the API -> https://www.peak-system.com/fileadmin/m ... -basic.zip
Here a link to the version history of PCANBasic:
https://www.peak-system.com/PCAN-Basic.126.0.html
This is also mentioned in the parameter documentation of PCANBasic:
Make sure to take a look at the new examples provided.
hugues.ostermann
Post by hugues.ostermann » Wed 1. Jul 2020, 10:00
Sorry, this is a common mistake.
Windows was using an older .dll than the one I expected.
Copying the version 4.4.0.288 in the root folder of my project solved the issue.
Many thanks for your help.
You can close the ticket.
Post by M.Heidemann » Wed 1. Jul 2020, 10:04
Thank you for your feedback!
-Closed-
Locked
