Error When Running PCAN-Basic
kbachovchin
Post by kbachovchin » Thu 30. Jul 2020, 22:13
I downloaded the PCAN-Basic API from the website
https://www.peak-system.com/fileadmin/m ... -basic.zip
I’m trying to run the PCANBasicExample.vbproj from the following folder that gets installed
pcan-basic\PCAN-Basic API\Samples\VB
However, when I attempt to run the project from inside Visual Studio I get the following error message:
“Unable to find the library: PCANBasic.dll”
Looking at the ReadMe.txt, I see it says:
If you build an application that uses the PCANBasic.dll, you need to to copy
the PCANBasic.dll manually to your Windows System directory.
Windows 32-bit systems:
32-bit DLL > Windows\System32
Windows 64-bit systems:
32-bit DLL > Windows\SysWOW64
64-bit DLL > Windows\System32
I’m using a 64-bit PC, so I copied PCANBasic.dll from pcan-basic\PCAN-Basic API\x64 to C:\Windows\SysWOW64. However, the same error “Unable to find the library: PCANBasic.dll” still occurred when running the project inside Visual Studio
I next tried to also copy the 32-bit PCANBasic.dll from pcan-basic\PCAN-Basic API\Win32 to C:\Windows\System32 even though I am using a 64-bit PC. After this, I got a different error when running the project in Visual Studio:
System.InvalidOperationException: 'An error occurred creating the form. See Exception.InnerException for details. The error is: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)'. Inner Exception. BadImageFormatException: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B
What do I need to do to resolve these errors so that I can run the project in Visual Studio?
Thank you,
kbachovchin
Re: Error When Running PCAN-Basic
Post by kbachovchin » Thu 30. Jul 2020, 22:21
I figured out my mistake. According to the ReadMe.txt, The 32-bit DLL needs to be copied to Windows\SysWOW64 and the 64-bit DLL needs to be copied to Windows\System32. That's confusing, but it works after doing that.
U.Wilhelm
Post by U.Wilhelm » Fri 31. Jul 2020, 08:25
No Problem - you are not the first who was confused about the naming that Microsoft use here...
we have some extra threads about this issue:
LINK1
and
LINK2
